Discuss primary ventilated stack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
BOBBOB
Hello all,
On a two story building, can the stack pipe exit the roof near the eaves, or must it exit near the ridge to work effectively?
Any help much appreciated,
BOBBOB
So long as it is over a metre above an opening window its okay.
You can check all the positions in the Bldg Regs drainage document H on line version free from government planning portal.
Reply to primary ventilated stack in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
