Discuss Problematic thread on TilersForums might be a leak in shower - can you help us? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dan
Administrator
Staff member
Admin
Okay okay so we're having to admit defeat in a thread and might actually (only might :D :D :D ) need the help of a plumber, or two.
Help! Tiled wetroom floor looks perfect but grout doesn't dry out!
Please checkout this thread. If you have a moment. If you want any of the images and don't have and account and don't want one, let me know, and I'll get the images for you.
We appear to have some grout that's pretty much permanently wet. Whether the shower is used or not. Took a couple of weeks (customer away on hols) for one area to dry out IN the actual shower.
Tilers has gone and re-grouted with Epoxy resin. (Can't let water through, either in or out from behind the tiles) so it APPEARS fixed. At least in the shower.
BUT - Now customer has water showing OUTSIDE the shower former area, and beyond the screen.
Can you helps us come up with a way to test whether it's the trap, or the mixer or some pipe behind the shower or something?
Hi Dan I've been following that thread with interest....what you need is a good plumber to have a look. Have you tried looking on the Screwfix forums? ha ha ha
Separate tiler and plumber....shower leaks 6 months down the line...who's fault is it?
Tiler for dot & dabbing or plumber for having a drip on a 1/2 male iron going into recessed shower valve.
Although it did dry out when she was on holiday....could be leak in pipe going to shower head if built in.
Help! Tiled wetroom floor looks perfect but grout doesn't dry out! | Page 6 | Tilers Forums | tile advice and tiling forum - Tiling jobs, tiling courses, tile adhesive and grout. Tile advice for professional and DIY tile fixers
An update.
The plumber has pressure tested the shower heads or something and it isn't that. Apparently at 2 bar it didn't drop at all over half a hour (is that the way to test leaks to showers?).
So does anybody have any clues as to what could be causing water to sit on top of the grout 2ft away from the trap?
If its a small weep not sure if half hour of testing would be enough imho.
Wouldn't be surprised if a pet cat is wee'ing on the floor
Paulas not having much luck with finding out an answer eh ??
exactly , also i just posted in the tiler forum as if the guy done the test using the shower valve to pump up pressure then switch off then hes only testing the outlets and not the inlets but only way to test the inlets is by switching mains off opening shower valve and switch main on , get pressure then switch off,,, only problem this tests whole house lol
try some drain dye down the shower waste, careful not to stain the tray and see if the grout picks up that colour, help prove the trap and waste pipe is watertight.
Nice one lame, that would defo eliminate the drain lol
been there and done it to find the leak before, nice when you end up with pink grout :) after some muppet has stuck some nails in your waste run for what ever reason :(
Reply to Problematic thread on TilersForums might be a leak in shower - can you help us? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
