Discuss Problems with hot water on a gravity fed system. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Asking for a neighbour. He has an old style gravity fed heating system with tank and immersion heater. He has just changed the pump and three way valve actuator. His heating works but if he selects hot water it turns the heating off. Any suggestions would be appreciated, thank you.
Hi, I think it's my neighbour who started this post for me...
I bought the correct actuator (3 port mid position)...
Here's the full circumstances...
My system worked fine for years until about 3 months ago when the system started with a fault that meant it would only do either hot water or heating, but not both at the same time (if I had both on then only the heating would work)
I swapped the pump out (thinking it was that) but then the fault changed, only the heating would work and once you tried to put the water on it stopped the heating completely, even after turning the water off!. I've now swapped the actuator but still the same latter fault.
The heating will now only work if I drain the system and start it and never use the hot water (or at least it's done it the last two times over the weekend, one each after changing the pump and actuator, I know I didn't need to for the latter but was the only way to get the heating to work) so I'm about to drain it again and refill it to see if the heating will start again.
All the wiring is fine, I took photos before taking the other one off, and put them back identically, plus the fault was there beforehand.
I really don't want to have to spend anymore money changing the controller and WiFi thermostat (unless that's the fault of course) just out of work thanks to Brexit so haven't got money to waste if that's not the fault & more importantly, the Mrs just come out of hospital so I really need to get this fixed for her, at least the heating as we've got the emersion boiler for water.
Oh yeah, I've also tried with the actuator locked open, still no good, and yes I locked it open before removing and locked the new one open while fitting.
I'm really stumped and desperate to get it fixed for the Mrs,
Hope you know something that I'm missing?
Thanks in advance for any assistance you can offer.
Cheers,
Woody
[automerge]1570463743[/automerge]
Is this post in the right place or should it be in the central heating section?
I think it would help if you can provide a schematic and a couple of photos of your system, please.
My first guess is that your hot water circuit may be blocked with sludge, which might have been the original problem. Another possibility is an an airlock.
I think it's the valve because even when it's manually locked open on ab the tap water still doesn't get hot so I think it's not opening properly, even with the new actuator.
I still would like a professional opinion though before I change it.
Just to clarify as another person I spoke to thought I meant I had no water...
I have a water flow out of my hw taps, it just never gets hot.
I left just the HW supply switched on for a few hours the other day whilst I had to go out, when I got back, the actuator was really hot as if the heating or water was working and flowing but neither was.
So the power is getting to it, it's just not functioning. 😪
I took the valve off yesterday so I could see if it was blocked and also so I know how it works on the inside.
No blockage and it moves easy with my fingers, very rusty looking so I've ordered another, but nowhere had just the valve so had to buy one with an actuator on!
I'm just waiting to get the txt to say it's arrived so I can collect it.
BEFORE I FIT THE ABOVE, it's definitely not the thermostat on the water tank (immersion heater) is it? I can't see how it can be if the actuator is getting the signal but unable to move the valve, but I'd rather not have to spend the money on it, so this will be my only chance cos once it's fitted I can't take it off and take it back.
* My junction box *
This is exactly as it was before I started doing anything and I'm taking it as granted that it's all correct because it used to work for 5+ yrs when we had the new boiler installed.
THAT BEING SAID...
Why is there a grey wire going into the earth? T9 second from right
If I touch the screw with my screwdriver it lights it up saying it's live, I didn't think that was supposed to happen???
Bottom Row
1 = E - Mains + Boiler
2 = N - Mains + Boiler + WiFi
3 = L - Mains + Boiler + Controller
4 = Boiler/Black
5 = WiFi/Black
6 = Boiler/Grey - WT/Blue
7 = WiFi/Grey - Controller/Black
8 = Controller/Grey - WT/Brown
9 = E - Controller + WT
10 = Blank
Top Row
1 = E - Actuator + Pump
2 = N - Actuator + Pump
3 = L - WiFi/Brown
4 = Pump/Brown
5 = Actuator/White
6 = Actuator/Orange
7 = Blank
8 = Blank ???
9 = Actuator/Grey ???
10 = Blank
Thanks to everyone for your suggestions so far, and can someone let me know if that T9 grey cable is correct.
Cheers,
Woody
Reply to Problems with hot water on a gravity fed system. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
