daiianto
Hi all,
I have Procombi 100 HE, which is a rebadged Volkera compact so Google suggests?
The gas supply was cut to this when my teenager erroneously thought he could smell gas when we out and turned the handle at the meter.
I switched the gas back on and since then the Boiler fan runs and it sounds as normal, but the green LED flashes about once a second and theres no heat/hot water. I have not seen any red LEDs yet. The loss of gas is the only thing that has changed that has stopped it working properly.
The boiler has been reset about 10 times by turning it to off and leaving it for 2 mins. Also tried switching off at the supply and repeating the reset process.
Any ideas would be gratefully received,
Thanks in advance
EDIT: Just tried to run up heating and led now changed to Red!
Thanks in advance
