Discuss Programmable room thermostat for ideal logic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PhoenixServices
hi guys.
After recommendations for a programmable room thermostat.
Preferably wired and if possibly weather compensation.
It is going on a older model ideal logic combi.
hi guys.
Someone asked this same question yesterday:
Best programmable room thermostat for old idea logic
Consensus seemed to be
Honeywell CM707
for the prog/stat. Weather compensation is a separate issue and I'm not sure that boiler has it as an option. Which model is it precisely?
needs to be logic plus for weather comp. also if you want to go down the weather comp route you need an open therm controller with it so the boiler can compare outside and inside temps and decide at what flow temp to fire the boiler. one without the other is just guesswork
Reply to Programmable room thermostat for ideal logic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
