Discuss Pump on 24/7 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Z
zambo
Not sure how long this has been going on, because I only noticed when the pump got a bit noisy, but pump is on day and night, including when boiler is not on. I can't switch it off at the plug when I go to bed, because heating/water comes on before I get up.
I assume pump should be switched on and off by the boiler coming on and going off, so assume it could be a pcb problem.
Could a temp solution be to plug into timer so pumb comes on and goes off with water/heating, or could this cause probs. I know I could have one for example if I got a temp power cut. What could happen for eg if boiler came on and pump was off.
Cheers in advance for any halp and advice.
youve got a fault, get it checked, using a time switch aint gonna sort it properly pump should only run on demand or for heat disapation depending on system /boiler youve got
depending on your boiler this sounds like a pump over run fault[poss pcb] or a wiring fault as others have advised get some one in to sort it
Boiler is Baxi Solo 2 50 PF, and I believe that the pump is switched on and off by the boiler rather than being wired to the timer. Looks like the only way I'm going to sort it is have a new pcb. Expensive, but it doesn't look like there is any other option.
Thanks for your replies.
Does sound like the pump over-run to me, is the boiler going off as could also be a sticking micro-switch on your diverter valve, had this a lot of times with Danfoss zone valves but the boiler also fires up.
Martin
Reply to Pump on 24/7 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My son has just had a new boiler fitted and hes noticed that the pump runs 24x7 even when both the heating and hot water are set to off. He’s...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
