Discuss Pump over run advice please. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
djh22
I've moved into a property with a Vittodens 100 boiler and I'm wondering if it's normal that the pump over runs continuously. The heat control knob on the boiler is set sorta midway at about 6 o clock and the tank stat is set to 50 deg. At the moment I'm only running the Hot water side,the heating is off via the room stat.
Any advice would be most welcome as the noise from the Grundfos is very annoying.
Thanks.
The 100 comes with a pump overrun lead. They quite often are nt even connected,( Viessmann are ok with that )
however your continually running pump is not necessarily the boiler controlling it , it maybe bad wiring , or a faulty 2 port.
You really need somebody to look at it for you .
Thanks Townfanjon, I've put some trial and error time to it today and fingers crossed I think I might have solved it, I've turned the heat control knob up to the 60 deg dot mark and turned the system off at the mains then restarted it after 5 mins and it seems that the pump is no longer over running and actually cuts out a few minutes after the boiler cuts off.So I'm thinking that the pump was over running because the boiler wasn't reaching the temperature that the tank stat was calling for.
Cheers.
Reply to Pump over run advice please. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hi everyone Some very helpful people on this forum (hi John.g) sorted me out with some issues with a faulty installation of a Grundfos UPS3 back...
I have a 23 year old Megaflo heating and hot water system powered by the original Thermecon oil boiler. One of the most common kinds of faults I...
Deleted member 120897
Can anyone help, please? I'm looking for a heating system circulation pump for a domestic install, with 3 speeds, where the speed can be toggled...
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts...
