Discuss pump over run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
buckley plumb
does anyone know any other makes than the baxi solo that dont need a permenant live and pump over run.got to do a boiler change and customer wants straight swap min cost.
I didn't think there were any band 'A' boilers that didn't need a pump over run.
I'm only aware of the Solo, I take it it is too expensive for your custard? Is it that much of a pain to run a cable to the pump location then?
There is one other on the market but I can't for the life of me think of it.
If it' just about price Main he-a is the same boiler as Baxi Solo but a bit cheaper and has less warranty
Potterton promax is a solo in different clothes. There is one from another manufacturer.
not so much the pump over run as the permenant live as well wiring centre and cylinder in loft boiler in extension quite a distance would have to run .may have to put cable in
Potterton Gold does'nt have pump over run or needs permenant live
I'm fairly certain the viesman heat only doesn't from speaking to the rep, and also intergas, though less certain on this.
Take care Roger, Viessman told us that as well about the heat only (compact W) & they lied !!! only found out on my own system when I watched it rise to 97 deg C when system switched off. I had a lot of trouble getting them to admit that pump should be controlled via boiler. There overheats are set 100 C & it did not operate ( got mighty close) but the heat exchanger does not like the thermal shock when the pump starts again.
Reply to pump over run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Went to a customer today their glow worm Ultracom 24 HE goes to fire up then cuts out turning the heating pump off, then does the same again...
