buckley plumb
does anyone know any other makes than the baxi solo that dont need a permenant live and pump over run.got to do a boiler change and customer wants straight swap min cost.
Discuss pump over run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
potterton promax
not so much the pump over run as the permenant live as well wiring centre and cylinder in loft boiler in extension quite a distance would have to run .may have to put cable inI'm only aware of the Solo, I take it it is too expensive for your custard? Is it that much of a pain to run a cable to the pump location then?
gold heat only is the same as the solo,promax,mainPotterton Gold does'nt have pump over run or needs permenant live
Take care Roger, Viessman told us that as well about the heat only (compact W) & they lied !!! only found out on my own system when I watched it rise to 97 deg C when system switched off. I had a lot of trouble getting them to admit that pump should be controlled via boiler. There overheats are set 100 C & it did not operate ( got mighty close) but the heat exchanger does not like the thermal shock when the pump starts again.I'm fairly certain the viesman heat only doesn't from speaking to the rep, and also intergas, though less certain on this.
Reply to pump over run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
