Discuss Pump over run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ive been to a customers who's looking to replace a 30year old potterton flamingo 50s, keeping same type of system, all the wiring is in the airing cupboard at the other end of the house, so ideally I need a boiler that doesn't need the pump over run as customer doesn't want his house taking apart, does anybody know of any other boilers other than baxi solo that doesn't need a pump over run. Or does anybody know any clever ways round it.
thanks everyone
thanks everyone
Hi get a Viessmann in there pump overrun not required,due to heat exchanger,great bit of kit can't go wrong,just make sure you get the air out heatexchanger which has a vent job done!
Which model would you recommend, never fitted a weissman. I assume it's just a straight swap wiring wise then.
Hi it's a Viessmann compact heat only,all you need is earth live neutral and switch live simple,just get air out of main heat exchanger on fire up.nice and compact size can't go wrong
HI doesn't it have a Ali heat exchanger ?also 2 year warranty not good and mixed reaction on service from heateam?!
I know nothing about them TBO,someone on here gave me this link yesterday.Your pretty limited to what you can put in without a pump & permanent live.The last one i fitted was the old ideal classic. Sorry can"t help anymore.
I seem to remember ermintrude saying that the logic plus heat only doesnt require pump overrun.
I may be mistaken but a quick pm to ermi or a browse of ideals tech literature online should yield you the required information.
No logic heat does but just pressurise and use logic system! Boosh no extra wires
Well u need to run 3 cores between boiler and ac
Don't now why more installers don't push customers in the direction of a system boiler. No more tank to worry about in the loft.
Existing boiler must have a switched live. Surely they must be a way to get a permanent live there.?
Easiest way is to move the controls to ac. Normally programmer next to boiler that way u normally have 7 cores or more
Reply to Pump over run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
PSxxxxxx
