C
charlie frederi
Why would you fit a pressure relief valve on the mains water supplyyeah i know of the trevi never come across one though.
yeah thats all i was asking charlie, a prv would have to be used, therefore i would personally use a pump on the cwsc for cold and hot cylinder no need for the prv then. But i see what system you would use - charlie im only on my level 3 myself in heat and vent so look for different ways of doing things and all views are welcome - more i know the better.
cheers
as the mans would have nothing to do with the cylinder.
you would use a PRV on unvented system yes
I would also prefer to use a pump for both feeds but as you go on in later work you will find this is not always possible as some times you might come across scenarios where the CWST may be to small to cope or the flow to the ballvalve is poor
cheers
what ever pump you may choose just be sure the cold water tank feeder is big enough to not get sucked dry by pump, also, use proper flange on top of cylinder to save sucking in air, hope this helps omigo
Spot on m8
