Discuss Purpose of a hot water return line and a check valve in the USA area at PlumbersForums.net
Please see the RED marked area; The Hot water service (HWS) rretun line having a Check valve what is the purpose of this valve here? also i can see a TEE in the HWS forward and Return line, it's the only thing will be available in the HWS F&R joint?
What i have understood is the HWS F&R pipework is in a circulation mode and from the TEE a pipework will serve the sanitary fixture, Am i right?
It’s there for the secondary hot water return
Same as the cv by the toilet tmv3 are you installing the pipework?
Not sure why you'd have the Non Return valve there? You'd have it located back at the cylinder with the circulating pump, provided that's the furthest point.
Commercial system have many legs off a src main not practical to run each back to the pump separately
It’s to stop the draw off being used instead of the main hot water service eg water doesn’t flow from the src
Edit as it missed part of the message off
Reply to Purpose of a hot water return line and a check valve in the USA area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
