Discuss Puzzled....please help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My first request for help.
I'm replacing a Drayton Tempus Seven with an LP822. Old wallplate not compatible, but not a problem - can change.
What puzzles me is no connection to pins 1 & 2. Just checking this is normal?
Really appreciate comments / explanation.
TIA.
Normally, this is what three and four are for.
It depends on the system whether you need anything else.
If you do not feel 100% confident, I would recommend getting a Heating Engineer or Electrician who does a lot of Heating control wiring.
Do you know what type of system you have?
Many thanks, 'Last Plumber'. It's a pumped CH / HW system dating back to 1991, with the original Ideal Mexico RS60 still in service - Got a gas safety certificate on it 4 months ago, and I was only changing the controller because the LCD had failed. All fixed, all good :)
Reply to Puzzled....please help! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
