Discuss quarter turn bath mixer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi chaps,
Can anybody identify this bath mixer ? Would any of the quarter turn bath revivers work - i.e. new cartridge and handle;
many thanks
dave
If you take the quarter turn cartridge out and take down to the local merchants they should be able to match up it up for you
Also take one of the handles with you and you might be lucky to get a pair of cartridges to fit the handles.
If it is 1/2" standard height cartridges then more likely you will get sorted.
Reply to quarter turn bath mixer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
