Discuss Question about lpg gas safe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got gas safe lpg engineer to fit pipework for boiler around building for gas
But got alarmed done all the work an put slabs down
as it doesnt comply with regulations is right by electrics next to ac units
Also is less then 30 from opening window and on wooden building
I'm a bit annoyed with the bill being nearly £1000 for a incorrect job
Can anyone advise on this
Hi boiler was already installed as its commerical property
Was a 3 building split
Boiler and radiators were already installed and was running on bulk tank.
but was not in suitable place as in other persons area
So had to get new pipework an bring it around the side of the building but was all done by lpg engineer who decided to stick pipework an he got the slabs sorted
Had calor reps out and were not impressed as they say the bottles are going to be only just under the window and not the 30cm clearance
Also has electrical cables for ac unit there
And timber building
Can supply pictures but have to be direct
Reply to Question about lpg gas safe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
