Discuss Quick question - Can i screw a 1/2" BSP outdoor tap onto this? in the USA area at PlumbersForums.net
Hi All
Looking to replace this so i have a standard threaded end outdoor tap, looks like they have managed to fit an indoor tap outside as is?
Will a standard 1/2" outside tap like this screw on where the union is?
https://www.NoLinkingToThis/p/outside-tap-with-double-check-valve-15mm-x/37241
Cheers
Reply to Quick question - Can i screw a 1/2" BSP outdoor tap onto this? in the USA area at PlumbersForums.net
