Discuss Quick question - Can i screw a 1/2" BSP outdoor tap onto this? in the USA area at PlumbersForums.net
Hi All
Looking to replace this so i have a standard threaded end outdoor tap, looks like they have managed to fit an indoor tap outside as is?
Will a standard 1/2" outside tap like this screw on where the union is?
https://www.NoLinkingToThis/p/outside-tap-with-double-check-valve-15mm-x/37241
Cheers
Reply to Quick question - Can i screw a 1/2" BSP outdoor tap onto this? in the USA area at PlumbersForums.net
Afternoon, all. Currently have proprietary diverter valve on shower riser with handheld outlet standard 1/2" BSP male and inlet also 1/2" BSP...
4K
We have an outside tap that is about 50 years old and has just literally exploded. (Fortunately, I had already fitted an isolation valve when we...
Does anyone know where you can by the old 1/2 inch stop taps? Or an adapter for the slightly bigger nut to 15mm? The thread on the body of the...
2K
I need to add a new water point for our plumbed in fridge freezer, only had one quote (based on pictures) but seems very high so just wanted to...
2K
