Discuss Quiet Whole house pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Hi, I am looking at putting in a new system where I raise the cwsc in the loft, put the cylinder in there and use a whole house pump to pump 2 bathrooms but not the toilets. Would like it to be as quiet as possible. Any recommendations? Looking at a couple of big shower heads in this and a bath.
Cheers
The 'secret' of quietening pumps in a loft is to mount them as close to a solid wall as possible and then to mount on as large a slab of 'proper' paving slab as possible. That minimises rotational pump vibration.
Using proper silicone based flexible hoses will isolate pipe transmitted vibration.
What I am actually thinking is getting using a thermal store and putting in a 5 bar single pump and then splitting it for hot and cold. The only thing is, they only have a gas boiler. No wood burner or solar. Maybe they could be persuaded
Dab e sys box
So, Gledhill say there system is not designed to work off a pump so not sure it will work not being under constant mains pressure. I cannot really see why it would not. Anyone?
Reply to Quiet Whole house pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
