Discuss Radiator Pipe Advice Sought in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all.
The current towel rail is 1000mm x 600mm and ideally I'd like the pipes coming straight from the ground into the rail. The distance between pipe centres is 695mm. I can get a 750mm wide rail but the centres with that are 705mm and that additional 10mm could cause too much strain on the pipes.
I guess I am brainstorming out loud here, but would it be feasible to knock a channel out from the concrete and see if a pipe can be adjusted closer 10mm? The piping is 10mm plastic and inside a conduit sheath.
Reply to Radiator Pipe Advice Sought in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
