I
imrreh
Hello all,
So I'm looking to sort out the central heating, I've done some calculation using a calculator at bestheating website and it has given me the following figures
So the first surprising thing was that the smaller room (bedroom1) requires a larger ouput rad, I can understand that there are 2 outer walls but does that really make such a difference? The current rad that is fitted is the smallest one out of all the bedroom and the room heats up reasonably well.
For bedrooms 2 and 3 I could use a radiator that is 400high x 700mm wide but that may look a bit odd as the windows are around 2m wide. So would it be ok to put wider rads in and use a TRV to control the temp?
room | Height | Length | Width | Window Area | BTU | Watts | |
Bedroom1 | 2.32 | 2.63 | 2.44 | 1.44 | 1666 | 487 | 2 outer walls |
Bedroom2 | 2.32 | 3.45 | 2.98 | 2 | 1329 | 389 | |
Bedroom3 | 2.32 | 3.81 | 3.6 | 1.96 | 1555 | 455 |
