Discuss Radiator trouble.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
ChristopherDoir
All my rads are working at full tilt, except two. The radiator in the living room is next to the boiler (oil fueled) and has little heat. The other is in the main bedroom (directly above the living room, same side as the boiler). The rads in the rest of the house are fine. Should I consider getting them flushed? I have bleed the life out of them. Thanks in advance for your help..
If there's a trv on the rad check the pin is not stuck in as this is fairly common problem.
Reply to Radiator trouble.. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
