Discuss Radiator Valve Sizes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Take the picture on your phone to screwfix with you they sell them fitted one today it's a standard valve bud
This valve has reached the end of its life and was leaking underneath where it's now covered in black RTV silicon. As said, the problem in replacing it is that it appears to have a 1" thread on the radiator outlet which must have been common when I fitted it 15 years ago. This size fitting no longer seems to be available unless someone knows better?
We have told you it's a stnd lock shield drain off
http://www.NoLinkingToThis/p/chrome...ff/36552#product_additional_details_container
When doing 6"- 18" gate valves there was a gasket, how do these seal then?
Just brass on brass mating surfaces
No, taper
http://www.NoLinkingToThis/p/chrome-angled-radiator-valve-drain-off/70408
Thanks snowhead, understand the taper there, meant under the nut ie usually expect olive or O ring.
Reply to Radiator Valve Sizes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hullo everyone its a while since I posted on here basically because i have had no plumbing issues however I have one now. My son recently moved...
Hi, I need to remove some radiators for redecorating and went to try and shut off the valves either side of my rad. I have TRV on one side and on...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
Hi all, have a radiator in the hallway which has never worked. When I bled the radiators few days ago I checked the hallway one, and it appears to...
Hi everyone. Apologies - I'm new, but I promise to try and be an active member of the forum :) We're doing some decorating just now and it was...
