E
egibberate
I've recently had some building work done during which three new 'double radiator/double convector' were installed. There are four radiators downstairs altogether. When the heating is switched on all the radiators are hot, however, after a while two of the new radiators go cold and one remains hot. If I bleed a cold radiator, cold water comes out (not air). If I switch the radiators off & then switch them back on half an hour later they're all hot for a while and then two go cold again.
Thanks for reading this & I appreciate your time & expertise.
