Discuss Rads too hot to touch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Worcester Heatslave 20/25 oil fired boiler 4 years old, diverter valve renewed 3 months ago.
I don't seem to have any control over my radiator temps they get seriously hot too hot to touch, not sure if boiler c/h stat is working how can I check, I have turned it fully down and it has no impact on the rad temps, I thought if it failed the water would boil and fetch out the over-temp trip, or is my room thermostat catching it before it boils?
Could I test it by shorting out the room stat and seeing if the boiler boils, or is there a better safer way?
I test with my digital thermometer clamped on to the flow pipe and adjusting the dial. If it had failed completely then the O/H stat should operate,it may have gone out of calibration.Is the sensor properly located in the pocket?
Reply to Rads too hot to touch in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jaga radiators (with heat-exchangers) have their own small fans, that "will modulate down when the room temperature is met – the room temperature...
Hi all. I noticed this winter my living room rad only get hot in the top half. Radiator is 1600mm(DP SC) double panel single convector. System...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your...
Hi, I have an 20yrs heat only potterton 50e boiler with 196x old house - suspended floor - designer radiators, open vent system and hot water...
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just...
