Discuss Rain/drench shower pressure in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
BennyB
I’ve been asked to install a rain/drench shower head.
I know these can be issue with low pressure.
Mains at garden tap is 1.5bar, combi boiler in loft about 5m up, then shower on second floor so below the combi.
I’m thinking this is 1 bar at the outlet and should be a good pressure for a 250mm diameter shower head, anyone think otherwise? Thanks
Reply to Rain/drench shower pressure in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
