- Messages
- 12
Hi, seeking some advice on a Rayburn and control of hot water.
Leaving out a very long story, my mothers house is about 200 miles away from me and she has recently moved into a care home. My brother and I need to renovate this from afar in order to rent it out to help with funds for her ongoing care.
I have never really shown very much notice in how this Rayburn integrates with the heating in the house, but now I have to show an interest. From an initial visit and dig around in the pipework it seems to me that there is a gas boiler providing central heating and controlled hot water via an indirect vented cylinder. The Rayburn is also gas-fired and seems to be feeding a secondary coil in the hot water tank via a pair of large (28mm?) pipes. I am assuming that this is a simple gravity-fed heating loop. First question: does what I have suggested here sound like any sort of typical installation, or am I maybe missing something?
The Rayburn is currently out of commission (no safety cert, as insufficient ventilation - another issue that needs sorting), but once it is up and running I can see no way of controlling the temperature of the hot water. Is that also normal for Rayburns? I guess that they are designed so that the water in the heating circuit never boils? It should now becoming apparent just how little I know about these things .
If all of the things I believe to be true are, and I wish to control the temperature of the hot water in the tank, can I install another zone valve in the Rayburn heating loop, electrically wired in parallel with the one controlling the boiler's hot water coil, or will bad things happen if I inhibit this flow?
Thanks for any advice.
