Discuss Re-Routing Soil Pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
Warbs2000
Afternoon,
I am looking to put a full width single story extension on the rear of my 1930's double fronted property. The bathroom is currently situated in the middle of the rear of the building with the soil pipes dropping stright down from the bathroom. The extension that I want to build is open plan incorporating the current space with the new space as one large kitchen living area. I would also like to have a vaulted ceiling on the extension giving as much space/height to the room as possible. My question is regarding how I go about relocating the waste pipes. The obvious one is to box them into a pillar that would be a part of the new space but this would land slap bang in the middle of the room which i would like to avoid. Is it possible to re-route them through the vaulted ceiling some how to the side of the house where we have another small bathroom in order to drop into the drains at this point?
Any advice on this would be great.
its very hard to give you a correct answer without being able to see you property. Yes svp's can be run many ways, you will have to consider min falls,avoiding bends and access for roding etc.... I you run it in the ceiling you may not get the ceiling height your after??
i would consider getting a local plumber or experienced builder around to give you advise and a quote for the work.
Don't you need building regs approval to change any underground soil pipes?
should not be a concern as building control will be needed when the building work is done anyway i guess.
Reply to Re-Routing Soil Pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
