Discuss re: Water Meter Red Triangle In constant motion in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Samjameson
Should the small red triangle on meter continually be moving? Checked meter after hearing water noise in garage. Want to know if it’s a Sydney water issue or do we need a plumber.
Nope you have a leak if you turn the internal stop tap off does it stop spinning I’m guessing the water meter is external
Reply to re: Water Meter Red Triangle In constant motion in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
