Discuss Recommend Exposed Thermostatic Mixer Shower in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi All
Just looking for some advice on which Exposed Thermostatic Mixer Shower (Bar Shower) would go well with the Shower Pump i'm getting installed.
So the pump is the - SALAMANDER PUMPS CT FORCE 30 SU REGENERATIVE SINGLE SHOWER PUMP 3.0BAR from ScrewFix - seems like a decent one for the money. Pump will power two showers
Im looking for a bar shower to contemplate its pressure. The shower itself is a half decent size but is quadrant shower area (en suite). The current shower system (fairly basic one off Victoria Plumb) is not working any more, with sticky handles and poor water circulation.
Ive seen the below shower system, but not sure if i need to buy a 3.0 bar shower system, to which i can only see like HansGrohe system, which isnt problem buying.
Triton Push Button Dual Head Thermostatic Bar Mixer Shower​
Again just looking for some advice and any recommendations here.
Appreciate the help
Why is it only a single pump.
Forget Salamander, atrocious product with atrocious customer service.
The pumps more important than the valve.
Apologies, its the dual shower pump, just copied the wrong description - its the one below
SALAMANDER PUMPS CT FORCE 30 TU REGENERATIVE TWIN SHOWER PUMP 3.0BAR​
This one seems ok, and plumber mentioned its one the better ones he has seen in use. This was a preference because of the brass ends and not plastic.... but seen others in similar design
Reply to Recommend Exposed Thermostatic Mixer Shower in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater systems in the house. This boiler was replaced by a combi boiler as it only heats the lounge and master bed and provides hot water to en-suite bathroom and...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar. Connect to this is a 1.5 bar Ora Salamander pump for a positive head, this was connected by a plumber of course and we’ve had it all rigged up...
Hi All. My Aqualisa Aquavalve enclosed mixer shower valve leaked and gave way and I am looking to replace. I am looking for recommendations what model would I replace it with and how would I replace it if I changed the model! I would like to change the type of model to a lever one. I have...
Hi Guy's, Looking for some advice on an issue I have having with a recently installed thermostatic mixer shower in my ensuite. Everything was working fine for a coupe of months however now the valve has started misbehaving which is resulting in having to turn the temperature valve round further...
I have a positive shower pump that works well with current gravity system and shower mixer. I want to replace shower and found a mixer valve I like on Victoria Plumbing- But the info on most of their shower valves states ‘Please note a positive pump will not work’ under any circumstances? and if...
Jeff50
J
