Discuss Recommendations On Plastic Soil/Waste Pipe Manufacturers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All
I'm drawing up a shopping list for all the plastic waste/soil/below ground discharge/Inspection chambers/gullies/guttering etc for my new build. What would be the recommendations of which manufacturers to be looking at with regards to cost and quality? . All visible external wastes and guttering on the exterior of the building would ideally be black or brown. My local merchants stock nothing but hunter but not really sure on the quality? Also considering Polypipe as a possibility as my local plumb center seems to stock a comprehensive selection.
Cheers Mark
There all about the same
We use polypipe
Hunter or polypipe would be fine try to stick to one or the other though cheers kop
Reply to Recommendations On Plastic Soil/Waste Pipe Manufacturers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3 or 4 ribs on it). It's painted in a fetching pink/purple colour in the photo. Tried to revive it with some grease before inserting a short length of...
Evening all. Not sure if this is the most appropriate place to post this in the forum, happy to move if not. I'm looking for a metallic 32mm matt black waste pipe, to match up with a matt back trap. The pipe that comes with the trap is 400mm, which isn't long enough for my installation. I'd...
Need some advice, neighbors sewer drain keeps blocking up every few months. My wife and I have always chipped in with the other three neighbors for unclogging tho we never experience ours clogging up. Sure we had it clog up once and had it blown out with high pressure water from local plumber...
Planning drainage for a new bathroom. Assuming that all the falls/gradients are correct is there anything wrong with this plan? Soil pipe from toilet goes through wall below the floor level so that I can connect a shower waste (wetroom so flush with floor). On the other side of the exterior wall...
1K
Hi all, Excuse the length but this seems like a complicated fix. I lived in a 1930s block of flats. Brick building with concrete slab floors. The waste stack is internal and bricked into corner of the bathroom. I noticed paint peeling and brown staining recently at the bottom near the...
2K
