Discuss recommended screws in shower area in the USA area at PlumbersForums.net
I've removed a shower seat whilst investigating a leak. I've noticed the screws securing the seat frame have rusted (see pic).
I'm interested in recommendations for screws that you would use in a shower area. I thought these were stainless steel screws but clearly not. Are stainless steel screws suitable in this scenario?
Normally use spax wirox washer head and normally use a bit of clear silicon on the rear of the brackets and a Small circle round the hole for the screw so once fixed water can’t track back there
As the head is exposed I'd still prefer stainless than coated in a shower room but that's up to you. A stainless pan head woodscrew should do it or even a small diameter stainless coach bolt, a flat head giving you more purchase against the steel support than a countsunk screw.
Reply to recommended screws in shower area in the USA area at PlumbersForums.net
Hi I had to remove the glass panels from this quadrant shower cubicle and I'm struggling to get one of the screens back in place properly. The...
Hi all. Has anybody ever experienced the middle leg of a shower base that stands on legs (such as the one in the pic) winding in over time, and...
Hi all I've got an old baby belfast sink I want to use and I'd like to mount it on old brackets... I've done a mock installation in another part...
The joint between my WC pan and the cistern is leaking - I suspect that the doughnut needs replacing. I imagine that this would be easy enough for...
2K
Hi, Today I noticed one of the tiles in my shower enclosure has a crack in per the pictures below... I'm not sure how long it's been there but we...
