Discuss Recycling oil pumps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
Ecoboy
Hi, anyone know if there is anywhere to send knackered Danfoss oil pumps to get them recycled? I have collected a few in my workshop now and I don't just want to send them for scrap. Cheers
Why worry about giving them into scrap man?
As long as they are properly recycled.
Unless you think they might be repairable. I remove solenoids for spares and put rest of pump to ordinary scrap. On the larger very expensive Danfoss pumps I guess it would be well worth having the drive pin replaced, as I did on one, if that's all faulty.
But on BFP 11, or 21 pumps etc, they are just too cheap to be viable for repair and usually worn gears anyhow.
Burner motors and circulating pump heads are worth selling as motor scrap due to their copper windings
Yup, £150 a tonne as of this morning
SCRAP THAT, BOY!!! :)
Thanks guys, I guess you are right, I'll just stick to chopping in copper and brass - like I did this morning, the ferrous metals can go to the scrap man for free. Cheers for the replies.
Reply to Recycling oil pumps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
