Discuss Red wheelie valve in airing cupboard in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
bob the bridge
Could you please tell me what the function of the red "Wheelie" valve, (picture attached) situated in my airing cupboard and whether it should be open or closed. Thanks
It's called a gate valve.
The function might be as a by-pass valve.
Count the turns from fully open to fully closed and go somewhere in the middle.
What's the problem with the system?
Many thanks for the reply, no real problem. I did not know what this valve was for. Nobody seemed to know. One guy told me it was there to assist in draining down the system but that did not make sense to me. The only thing I noticed is that when the valve is fully closed with the CH off, the pipework makes a rushing noise. I have only just had the system refurbed and did not want to mess things up. thanks again.
As Oz says it needs to be open
It looks like a basic bypass which will let water flow when both two port valves are shut and the pump over run is active. The valve should be opened enough to let a flow through. Sometimes it is connected to the towel rail circuit.
Might be better having a proper automatic bypass valve fitted, rather than an always slightly open gatevalve, in my opinion. Needs a heating engineer to do it and set it though.
My thinking is an auto bypass valve will remain fully closed unless the system needs it to open, when little or no flow is happening. But a gatevalve always open just derates the circulating pumps ability to pump around rads. Really just short circuiting a pump
Reply to Red wheelie valve in airing cupboard in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My family and I live in a bungalow, we have lived there for nearly five years. The property was built in 1964. I want to turn off the water supply...
The pipework around the hot water tank in the airing cupboard has developed several leaks after a chemical flush. It's an open vented system...
Trying to find out exactly what happens when my system boiler is called to supply the radiators and hot water cylinder at the same time. For...
We have just moved in to a 12 year old house with a system comprising of a gas boiler with header tank and hot water cylinder also with header...
Hi. I replaced the Pressure and Temperature relief valve on my MegaFlo CL300 (I had thought it was dripping but it turns out the overflow drip...
