Discuss Reduce length of copper pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
HiVery hard to understand the question and what you are trying to do.
Firstly, I would always try to replace radiator valves with a new valve that allow pipe the same full length.
A junior hacksaw will easily cut as little as 2 or 3mm off the end of a copper pipe. You are obviously not used to working with a junior hacksaw.
As you were able to get a pipe cutter/slice in place, - you definitely could have got a junior hacksaw at it.
Often it can necessitate just an inch of blade travel, (maybe wall in the way etc) but new sharp blade and patience will help.
There is also a junior hacksaw that has a triangular shaped frame for awkward spots.
You really need saws with full frame to keep blades held rigid. But the handle type that holds the large hacksaw blade is also useful in near impossible jobs.
Pipe cutters aren't designed to cut much below 1/2" off a copper pipe. The rollers have very little to steer on and the pipe tends to squeeze in where the blade is against and this makes pipe slices, with their constant heavy spring tension on their blade, worse on end of pipes. Ordinary pipe cutters (small or normal size) with slight manual adjustment of blade would be more possible, but still not ideal.
Using hacksaws is a skill we don't think about, until we see somebody struggle using one. Got to go gently and constantly check blade is going straight.
I have no problems at cutting pipes when access is easy and you can see what you are doing, being an ex joiner I think my skills with a saw are above average,
Granted - you can cut timber better than the average person and most plumbers
but when it becomes awkward or impossible to use a saw on wood I revert to a sharp chisel job done in no time.
Plumbers are well versed on the awkward and impossible - bit none of us own sharp chisels
I just thought in todays world, plumbers would have found an easy way around the problem,
We have - we keep our knowledge inbred - much aligned with our DNA
on new work as long as measurements are correct you should never need to use a saw.
We're Plumbers - we can't measure.
That's why we solder pipes, use couplings and have most of our work covered and concealed.
I think the gas engineer has a good solution, to use a small grinder, but then you have a problem with the bits getting into the pipe, but the Magnaclean should catch them.
Copper is not magnetic - Magnaclean would not catch copper particles - unless covered in magnatite.
Can I thank everyone for taking the time to join in the discussion all comments appreciated
Our Pleasure
I use a stnd big hacksaw blade (24t) and a glove
But then again I'm strange
I appreciate you must be good with a lot of hand saws, as you are a joiner. Although every tool, as you know, has a certain time earned skill needed, - even a junior hacksaw. I know joiners can use Coping saws no bother, yet I would struggle. Pad saws are also hard for most trades, except joiners, although I am well used to them and don't use too much force.
Normally, even on very awkward cuts, the junior hacksaw can be used from the front, often cutting with just 2 or 3 teeth of the blade as there is so little space. That's why I always use brand new blade in tight spots. On rare occasions I use a large hacksaw blade just.
Here is a similar sort of junior hacksaw for tight spots, but not the quality one I am thinking about.
junior hacksaw for awkward cuts - Google Search:
You could also use one of these, but blade can flex too easy, -
Junior/Mini Hacksaw 10" 250mm Tight spot/Restricted Access Hacksaw & Blade | eBay
A hacksaw blade only cuts in one direction. Often, especially with a junior hacksaw, reversing blade so it cuts on the pull stroke will overcome problem.
This is the way I do it. I have a 300mm hacksaw blade out of the frame with a handle made from some gaffer tape, set up to cut on the pull direction. It can be slow going but the harder hacksaw blade will always win against the soft copper. You are basically slowly filing your way through. It takes some time and patience but you'll get there.
I met my wife this way, she thought I had worked really hard cutting through a tight cold water supply for a shower I fitted for her (because it took a while). She even bought me a pair of jeans as a bonus. Never to this day did I tell her it was easy. Other than patience and 23 years of marriage no problem.
Hack saw blade every time
Reply to Reduce length of copper pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
