Discuss Refilleable blow torch connector ?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi peeps,
Just a quick question, where’s the best place to get a blow torch connector that’s fits in my Rothenberger and a refillable bottle ??
Cheers
Do you mean the adapter that has threads one end for into a Roth SF torch and the other end for a gas hose to push over and clamped?
You should be able to order it from a plumbing merchant who does Rothenberger, or online.
I have one myself, but just use now the single use direct screw on gas bottles
I think he is after the adaptor for refilling a Blowlamp gas cylinder from the standard LPG cylinders
Hi peeps,
Cheers
By 'Rothenberger' I assume you mean the Super fire 2 Blowtorch
and 'refillable bottle' I assume you mean the Primus 2000 Cylinder
In that case you'll need the adapter:
Part No. 3.5653
You can find it here:
Rothenberger Primus 2000 brass torch adaptor | Wolseley
Reply to Refilleable blow torch connector ?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
