Discuss Refilling underfloor heating in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, gotta a bit of an issue with refilling my underfloor heating. Am I right in saying that the flow meters along the manifold should be on the top rail, but as you can see they are at the bottom?
Also have I got to loosen off the electrical actuators at the top to refill the system?
Cheers
Can anyone help with this underfloor heating question?
Reply to Refilling underfloor heating in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I'm attending a wet underfloor heating system, it's an old one ..No flow meters, just adjustable valves on the returns with conventional...
losing pressure
L
I am seriously stuck with an underfloor heating system which isn’t getting warm enough. I have previously had it working perfect in January...
2K
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
Hi all. We have underfloor heating on a couple of levels in our house. One floor was not heating and I asked advice from a plumber we have used...
