Discuss Remeha Avanta plus 24C in the USA area at PlumbersForums.net
Remeha advantage plus boiler
Hi Ashley here, I have an enquiry about my Remeha advanta plus 24c boiler.
the remote timer/ thermostat unit has a clock that is not working can I get a new clock or a new control unit for it.
what are my options ?
thanks
Reply to Remeha Avanta plus 24C in the USA area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
