Discuss REMEHA AVANTA PLUS BOILER, NO HEATING ON RAD BUT HOT WATER COMING FROM TAP. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Tony
Hi everyone
Am having challenge on REMEHA AVANTA PLUS BOILER.
When the room thermostat call for heat on rad no response but when the tap is open hot water comes out.
When the boiler is on SERVICE MODE central heating working but tap water is cold.
Please I need help on how to put things right.
Your advice will go a long way
MERRY CHRISTMAS EVERYONE.
Thanks.
In service mode it usually the water is circulated around the heating circuit. That’s why you have cold water.
I would try linking the controls out.
Make sure all the taps are closed or alternatively isolate the cold water inlet to the boiler.
Thanks@AMGas service.
My challenge is when the boiler is ON and I call for heat on radiator, NO HEAT ON RADIATOR.
Any ideal what could be the cause.
Reply to REMEHA AVANTA PLUS BOILER, NO HEATING ON RAD BUT HOT WATER COMING FROM TAP. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
