Discuss Remove an ‘Edwardian’ shower diverter valve in the USA area at PlumbersForums.net
Hi all,
Hoping you can help? The spindle has snapped on our diverter valve so presumably it needs to be changed. I’m struggling to get the old one out though...is it just brute force turning it anti-clockwise?
Driving me crazy?
Yes I’m afraid it is.
If you have a socket set that might be easier, make the handle longer to get more leverage.
Or best is probably a nicely fitting ring spanner, don’t be afraid to hit down on the spanner with a hammer if necessary, or if you have another bar/box spanner you can use to make it a long handle you’ll be able to undo it with your pinkie!
I’ve got the fitting off, my problem, and yours too Aideen is the crank has snapped, where to get a new one , 3 plumbing shops in Geelong yesterday and no luck!
Reply to Remove an ‘Edwardian’ shower diverter valve in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
