Discuss Remove TMV under bath in the DIY Plumbing Forum area at PlumbersForums.net
Hi All
I'm about to fit a thermostatic bath/shower mixer tap to create a shower over the bath. As it's a new build property there is already a TMV under the bath to limit the temperature of the hot water.
Should I remove the TMV under the bath and rearrange the pipe work to give single hot and cold feeds to the thermostatic tap or can I leave the TMV in place. Any advice would be greatly appreciated.
1. If you leave the TMV in place, the hot will always be limited to the temperature set on the TMV. It can never be delivered any hotter.
2. If you are adding the shower, but leaving the bath in place, you could take the hot and cold feeds from the input side of the TMV, which effectively cuts it out of the shower circuit. The bath would remain limted by the TMV, thus reducing the risk of scalding.
Thanks for the reply.
The shower is a combined thermostatic bath tap and shower. The Aqualisa Midas 110 (pic). Which I assume would regulate both the shower and bath filler, doing away with the need for the under bath TMV altogether. However, it would be easier if I could just leave it in place. The TMV is a Pegler which is preset to 43⁰C according to the spec. From reading through various sources I believe this is a max preset temp of most thermostatic valves. Though I understand that there is the possibility to adjust. Assuming I'm happy with the temp range, will this arrangement have any effect on the flow rate or cause me any other issues. Thanks in advance. Screenshot_20210518-161420_Chrome.jpg
Also check, some of those mixer are thermostatic on the shower only. The bath filler is often not, this allows bath to be topped up with hotter water and also will fill a bit quicker.
Some thermostatic mixers will always deliver no hotter than 10 degrees below the inlet hot water temperature. Others, 2 degrees.
You might accept a maximum bath tap water temperature of 41 degrees, and it will be fine for a shower. If it's effectively limited to 33 degrees, it will be terrible.
Reply to Remove TMV under bath in the DIY Plumbing Forum area at PlumbersForums.net
We have had an ongoing issue with low hot water temperatures in a school. During the recent repair of a leak, the plumbers isolated the hot...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
T
I am redoing my bathroom and not sure what the best way of doing my shower is which is in my bath, I want a rain shower and so I was thinking of...
Thermostatic shower
T
A
The bath taps have 22mm inlets currently the cold water mains 15mm is fixed to the tap by a copper adapter 15mm to 22mm. The hot water is 22mm...
1K
Good morning! First post looking for advice on an issue I am having with a bath installation. Although I have installed many baths before, mainly...
