Discuss Removing Air Con units? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
TBServices
Been asked to remove some radiators and pipework in a property. They've also asked if can remove an air conditioning unit, to which I replied they probably need an F-gas registered guy, was I correct or did I shoot myself in the foot?
Yeh you shouldn't discharge to atmosphere . But a few boys and girls do.
Not worth it tom. You wont know what refrigerant is in it depending on the unit age.
last thing you want is refrigerant burn/frostbite.
Some of the older refrigerants can be really nasty for your health too... I wouldn't fancy a face full of Methyl Formate, Chloromethane or Ammonia.... To be fair they'd have to be old units and predate the now obsolete CFCs and modern refrigerants.
If the units still operate they can be pumped down to contain the refrigerant in the outdoor unit, if not the refrigerant would have to be recovered. But by the letter of the law you need to be F Gas qualified/registered regardless, because you would be deemed as working on a refrigerant system/circuit.
We're f-gas and cover the south midlands so you can always give us a call :)
Turns out the room is going to be turned into a refrigerated store, so the guys doing the fridges are removing the AC.
Reply to Removing Air Con units? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Apologies - I am not a plumber - not sure if it is ok to post here but... It's freezing and my boiler is not working so, I wonder if anyone can...
E
I reckon if I did a survey of 100 heating engineers, asking what would they recommend for heating a granny annexe being built onto the side of my...
eco-heating options
E
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The...
Hi all, Got a nightmare situation with a central heating system I recently adopted. It's an open vent system with a combined F&E pipe, with a...
2K
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
