Discuss Removing recessed aerator which has crumbled? No grooves for aerator keys! in the USA area at PlumbersForums.net
Hi - we came back after a few months to our flat and all taps in the flat have fine water pressure except one bathrooms.
I think the tap has become clogged up and i think it has a recessed aerator.
You will see in picture 1 and 2 (number in red in top left) - this is the tap and can see the setup. I could not see any grooves on this to work out how to remove like other aerators. I then tried to just use some pliers to twist it out and it just crumbled.
In picture 3 is the actual problem tap. In this picture I have now removed the crumbled outer plastic (the dark grey stuff in picture 2)
However, I am now left with this white bit of plastic and not sure if the answer is to just literally poke it out but i dont want to do any damage.
I am after some help to get me back to normal where i just have a working tap.
Do i just literally use some pliers and force out the white bit of plastic as well?
Can you point to where i might get a replacement aerator?
Any advice on how i remove the last white plastic bit would be great and where i can then get a replacement.
Thanks so much
Jazz
The chrome ring unscrews to release the aerator and remaining restrictor / spreader.
It will be tight if it's never been out.
New fittings available, just need to work out the size,
Reply to Removing recessed aerator which has crumbled? No grooves for aerator keys! in the USA area at PlumbersForums.net
