Discuss Replace Aqualisa power shower to mixer shower in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi - I want to replace Aqualisa power shower to mixer shower to a std. mixer shower, however, the centres for the hot and cold are only 65mm. I’ve tried finding something that would be compatible but no joy. Ideal would be a mixer head with the same centres. Does anyone have any idea as to what I could use?
There was a similar question on this forum in 2012, and one on diynot a couple of years ago, and the replies to both concluded that nobody knew of any other shower mixer with 65mm pipe centres, and the only way was to modify the pipework.
If you’re not comfortable in adjusting the concealed pipework and you’re not too worried about looks.
You could get some chrome pipe/elbows and surface supplied bar shower wall plates like below.
Reply to Replace Aqualisa power shower to mixer shower in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
