Discuss Replace Aqualisa Quartz in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Unreliable? They're certainly ugly but I can't say I get many problems with them.Anything other than a new Quartz shower! Terrible showers and unreliable.
Just fit a shower that has cable and pipe on right hand side.
You have plenty space around that shower and a multi fit Mira might suit.
Redring also suit.
The showers installed wrong. Why have the spacers been placed over the cables and not used to pack the shower of the wall? Isn't this required by the manufacturer to allow air flow for cooling the unit. Could be why he's having issues.
But if your customer has lost faith then the Mira sport multi fit is probably your best option.
Is @armyash the installer?Good grief! I hadn’t realised the cables were put through the shower spacers!
That shows the installer hadn’t a clue.
Far from perfect, the insulation round the cable is cut too far back, There's a clear line about 50mm below the earth connection stating not to strip back the insulation below that point. Also no silicone round the screws or the hole where the pipe and cable come through the wall. The shower hose is also not within the retaining ring, but we can't blame the installer for that as it's usually the first thing the customer doesOops! Maybe he was.
I didn’t think on that possibility!
..otherwise it looks a perfect install
Reply to Replace Aqualisa Quartz in the Plumbing Jobs | The Job-board area at PlumbersForums.net
