Discuss Replacement shower valve reduced water pressure -need to replace again in the USA area at PlumbersForums.net
A
Alicia
Hi we had a Thermostatic Aqualisa shower valve upstairs that was tank fed upstairs in our house and it had great water pressure. We recently had our shower completely redone and the valve the plumber put in doesn't seem to be very good and the water now has very low pressure. We know the system is OK because the pressure used to be great and our mains pressure is great. Can anyone recommend a valve we could replace it with that wouldn't require redoing the tiles etc? E.g. an easy swap?! I can't find the exact valve he fitted on the web but it is similar to this one (Sagittarius Como Shower Valve | SH/269/C | Exposed | Chrome - https://www.heatandplumb.com/acatalog/sagittarius-como-shower-valve-sh-269-c-1633574480) ... it is a manual exposed mixer value with 150mm pipe centers. I would also like to replace with thermostatic if possible - will this help with pressure? Thank you very much
Unfortunately no mixer these days is compatible with gravity system there too restrictive
Thanks - do you think we could see an improvement with a more expensive valve? The old aqualisa one we had was great but it was recessed. I'd really like to find an alternative exposed valve which would be an easy swap. Thank you
Sorry to say no shower pump is the only option the old one would of been suitable for gravity
Mira Coda is for low pressure if I remember correctly with 150mm centres. Put unsure if it'll go on your pipework as you'd need a fastfix kit.
Tbh as Shaun says you'd be better upgrading to a high pressure system or pump.
When you say that, are you also thinking of the Mira ones designed for low pressures, and when you say 'too restrictive' is that because people's expectations have also changed?
Reply to Replacement shower valve reduced water pressure -need to replace again in the USA area at PlumbersForums.net
