Discuss Replacement thermostatic radiator valve heads in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I installed central heating in my house about 22 years ago using bog standard Screwfix 15mm angled thermostatic valves marked E.C.A. where needed.
The plastic has become brittle with age so the lugs which are clamped by the retaining ring have snapped off. I'd like to just replace the head but need to find compatible ones. My son has replaced two of his heads with so-called smart ones. I thought I could use his old ones which have the same size retaining rings (M30 x 1.5) but the hexagonal recess which fits over a nut in the static part of the head is smaller than that of the Screwfix valve (15.7mm hex A/F vs 18.8mm).
Any ideas where I can find compatible ones?
Just replace the whole valve.
Stop being cheap
How do you know new trv heads will work or maybe the valve will malfunction in a day, week etc. then you have more hassle.
Do the job once, do it properly
Reply to Replacement thermostatic radiator valve heads in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
