Discuss Replacement TRV RADIATOR VALVES in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good evening
I need to replace 5 TRV valves in my flat . I would like to replace with decent quality ones. Does anybody have any recommendations Which would be very much appreciated.
I have attached a picture of
current trv.
Thank you in advance
Peter
100% agree with the above danfoss ras c2 bi directional so if one is on the return it doesn’t matter just follow the instructions and your good
Good quality trv that looks good and for a decent price
I have just moved from Honeywell to these. I find these better quality personally and they are the same price range as the Valencia’s.
A lot of companies say that there TRV’s are bi directional but after a few years you get a dull bang from them. These have a mechanical part you position when the valve is on the flow or return.
Honeywell Valencia are my choice but to be honest are starting to look a bit dated , however I have fitted hundreds and never had to change one.
Hello Townfanjon
Thanks for your swift response. I will have a look at them
Kind Regards
Peter
[automerge]1571333568[/automerge]
Thank you
I will have a look at thee as well
Peter
[automerge]1571333596[/automerge]
Peter
Hello Again
Thanks for all the helpful recommendations. I have been reading online today and the Danfoss TRV’s seem to get a lot of positive comments. It there any point paying any more than this price range for a TRV or not really . The original ones I have are the cheapest so I have been told and I don’t want to make the same mistake again.
thanks again
Peter
[automerge]1571417211[/automerge]
Thanks Chalked
Reply to Replacement TRV RADIATOR VALVES in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
