Seanog
Hi, I want to replace an approx. 1 meter section of underground sewer drain where I hope to locate a blockage of dried cement (from a new extension building project). MY question is what would the exact procedure be, if for example, the pipe is 15 cm in diameter. Would I just use a 1 meter length of new 15 cm dia. pipe, connected with Fernco connectors? I was wanting to avoid any "lips" at the joints which may slightly impede flow. Thank you. |
