Discuss Replacing a drain on tiled shower base. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
C
Cammelbdrainreno
Hi, my square drain had dropped slightly in one corner and needs to be raised and replaced. Am l able to remove the entire sleeve for the drain and replace it with a new one? How do I remove the square metal sleeve without removing the surrounding tile?
Reply to Replacing a drain on tiled shower base. in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
