Discuss Replacing old pipe work in the The Welcome Wagon :) area at PlumbersForums.net
Hi everyone. Hope your having a nice day.
I was wondering if anyone could help with the following ?
The existing hot and cold water pipe that leads to the bathroom on the first floor needs to be covered in the kitchen. I was proposing to do this with a plastic double pipe cover. The problem is there is a tee joint that sticks out as seen in pic 2. Should the whole tee joint and part of the pipework be removed using a reciprocating saw, then join both ends using a pipe plastic ? Is there a type of compression straight coupler to connect a plastic pipe and the old piping ?
I would greatly appreciate anybody s advice in this matter cheers.
Thats old galvanised steel pipe and should be completely removed if possible.
The only reasonable thing to do to the existing pipe is make it the same as one behind (with plug straight into Tee) should probably change for brass plugs, for what its worth....
Reply to Replacing old pipe work in the The Welcome Wagon :) area at PlumbersForums.net
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
A
Hi, I am replacing a leaking push fit flexi tap connector under the bath with a compression fitting flexi. The problem is that the old pipe seems...
Hello guys, a couple of months back I installed a new shower and sink into a part of the house that hadn't previously been plumbed in. This forced...
